bizhub 360 only prints 2 sided from the computer
  • brent
    • Nov 2008
    • 1214
    went through all the settings that I know. through the print driver pcl6 I believe. I can hit the default and apply button. but it wont stay. what am I missing.. ps. manually I can get it to print single sided only. but the customer wants to select it to do a 2 sided if t hey want. not automatically
    thanks
    brent
  • Darren King
    copiertech
    • 652
    Re: bizhub 360 only prints 2 sided from the computer
    Are they printing PDFs from Adobe reader 10? It is defaulted to two sided printing and you have to select one sided manually. There maybe be a way to default it to one sided but, in the brief time I spent on it I didn't see one. I just downgraded my Adobe Readed to 9.x.
    Hope this helps.
    Darren
    • brent
      • Nov 2008
      • 1214
      thanks darren. that is interesting. I am sure it is adobe 10. I have not seen that platform before. and yes it is stuck on 2 sided. I did sit at the workstation and looked. but couln't figure it out either. I will do some more checking. hope someone here has ran across this as well. thanks
      brent
      • emujo
        • Jun 2009
        • 3009
        All of the recent C652/C764 installs have had 2 sided as the default...I chalked it up to the KM green program..Interesting thought that Adobe 10 might be setting the printer defaults..Emujo
        • SmellsHot
          Head Tech
          • 512
          Yea that double sided default in the driver is more of a hassle now! Thanks for nothing Konica.....
          Everyone has the right to be stupid. Some people just abuse this privelage more than others
          • kronical
            Kronic Copier Ninja
            • Nov 2009
            • 230
            he drivers KM provides will only default to duplex if installed using the setup package. Throuh the wizard it does not do this.
            I have not run into any issues with this on Adobe X, either the reader or pro.
            Make sure you are setting the defaults on the printing defaults button under advanced. Especially if it is a server deployed driver. (will also need to be set on server in same manner)
            • brent
              • Nov 2008
              • 1214
              well crap. I did sit and try to get it to accept the 1 sided only as a default. but it just wont keep that setting. I will keep on tryin. any other suggestions are greatly appreciated. thanks
              brent
              • TheOwl
                • Nov 2008
                • 1732
                Is the driver shared from a server or another computer on the network? If so, you will need to change the 'Printing Defaults' which will change the settings for all of the clients connected to that shared printer.
                If you have installed the driver on each PC, then you will need to go through Start - Printers and Faxes (Devices and Printer on Windows 7) - Printer Properties of the driver concerned - Printing Preferences
                • brent
                  • Nov 2008
                  • 1214
                  we installed the printer drivers on each workstation. thought about putting it on the server as well.
                  I will take this information and fix em. thanks. very informative
                  brent
                  • Avskrap
                    Partner in crime
                    • Jul 2011
                    • 160
                    Printer Properties -> Advanced -> Printing Defaults. Even if you change it under Devices and Printers, the setting won't stick for some reason or another. Go through the Printer Properties, and check Adobe. We've had numerous calls from customers experiencing this, where they upgraded Adobe and now it's stuck to duplex printing.
                    What kronical says isn't correct, since we never install printers with the package, only through the wizard and it always defaults to duplex printing.
                    • kingarthur
                      • 1400
                      we had this problem with a C652...make sure that you are using either the drivers on the disc that came with the m/c..or downloaded from KM....dont use the ones that come with windows...you can tell which ones they are...if you use the ones with windows...when you go to the printers and faxes..the printer picture is just an ordinary printer..but if you use the correct drivers..you will actually see a picture of the correct mfp...
                      • brent
                        • Nov 2008
                        • 1214
                        we did use the drivers that came with the disc in the new mfp. so by using what avskrap says. will this work then?
                        thanks
                        brent
                        • Avskrap
                          Partner in crime
                          • Jul 2011
                          • 160
                          thanks
                          brent
                          Always works for me. Remember checking Adobe, it's been messing with alot of settings since the update...
