Scheduled inspection device bizhub 363
  • aleksander
    • 378
    Message "It is time for the scheduled inspection of the device" displayed on bizhub 363's panel. But no problem for copying, printing & scanning function. Anyone have experience with this problem? What should I do?
    Thank you for any solution.
  • JustManuals
    • Jan 2006
    • 9838
    Re: Scheduled inspection device bizhub 363
    Paul@justmanuals.com
    • aleksander
      • 378
      There is no explanation for this issue in service manual.
      • Avskrap
        Partner in crime
        • Jul 2011
        • 160
        Check the life counters for the parts. Order a PM kit. Change the parts in the PM kit, then proceed to reset these counters in the service mode. Inspect the fuser, if it's close to it's PM interval you might as well order a cleaning web assy and change it.
        Just remember to reset everything you change in the machine or you'll never get rid of the message.
        • kingarthur
          • 1385
          when you replace the "paper dust filter" which is in the drum kit, dont forget to reset it...or you will have an "L4" code
          • EarthKmTech
            Step aside, noob
            • May 2009
            • 2139
            i presume this is a taken over machine sold from another company or rebirthed
            that message comes up because someone has programmed the maintenance counter. just reset it and disable it.
            In my experience this counters only used by company's trying to offer the illusion of value for money for contract customers by performing "preventative maintenance" ie, making the technicians feel like glorified toilet cleaners going around cleaning photocopiers all day.
            If rollers etc are cleaned or replaced on parts replacement calls and the machine given a general clean, there's no difference to the machines reliability anyway. Its just a total load of wank (unless your talking about the set PM cycle machines, which yes,they should be done as per the book)
            • aleksander
              • 378
              Unfortunately your presume is Wrong. That's a brand new machine (not taken over machine) and I forgot that I've ever programmed the maintenance counter just for a test. I missed it.
              • Colobosto
                • Oct 2013
                • 5
                To Make this message go away you have to go to
                service mode
                Counter
                Maintenance
                Touch maint. - count and then c(keypad)
                End
                Exit
                And congraratz... The message is gone.
