i want to know what effect is of LD biss adjustment on my di450
  • zeeshan_xz
    • May 2025
    [Misc] i want to know what effect is of LD biss adjustment on my di450
    i want to know what effect is of LD biss adjustment on my di450? what is LD Bias Means?
  • mo0651
    • 1054
    Re: i want to know what effect is of LD biss adjustment on my di450
    It means if you start messing with it, and you don't know what you are doing, It will not like you!
    • JustManuals
      • Jan 2006
      • 9838
      http://www.justmanuals.com
      Paul@justmanuals.com
      • 907tec
        • 434
        Well, I'll tell you enough to get yourself into trouble: LD Bias refers to Laser Diode Bias. It will essentially balance the output of your laser to adjust for changes in the operating environment, such as degradation of the drum. Long story short: if you just learned what the "LD" abbreviation stands for, don't touch it.
