Rebuild image unit BIZHUB C450
  • smart-refill
    • Jan 2012
    • 27
    Hello
    Can I rebuild image unit of BIZHUB C450? If it is possible, is it difficult to do this?
    My OEM OPC Drum from the black image unit is scratched.
    I can find to buy a separate OPC Drum + chip for this device and I will try to change it.
    Could you tell me what are the steps to change the OPC Drum of this device?
    Thank you!
  • kingarthur
    • 1385
    Re: Rebuild image unit BIZHUB C450
    it is fairly easy...as long as you have lots of space & take your time...most drum rebuild kits come with instructions just follow them & make notes as you go along for when you reassemble it
    • smart-refill
      • Jan 2012
      • 27
      Thank You!
