Konica Minolta C552 dot lines on image
  • huney
    • Sep 2025
    Hello guys
    Urgent help please, image problem as attached on copy and print output
  • Zeldaman
    • Mar 2011
    • 946
    • mo0651
      • 1054
      Re: Konica Minolta C552 dot lines on image
      Looks like Laser. Does it happen on single color copies?
      • Albonline
        • Sep 2008
        • 1154
        One word RAM
        • huney
          yes it appears on single color also.
          Albonline can you explain more please? are you sure?
          • EarthKmTech
            Step aside, noob
            • May 2009
            • 2139
            Order the mfp board + ram module (its usually the soldered down ram on the mfp board that fails, not the module so mfp board replacement is usually required)
            Try the ram first, if no good, replace mfp + ram.
            Am i sure? Im fkn certain.
            • huney
              i try the RAM and still the same problem, i don't have mfp board in stock. do you have any idea about mfp board price?
              • EarthKmTech
                Step aside, noob
                • May 2009
                • 2139
                figured as much, im yet to see that issue caused by the ram module, but its always cheaper to try first
                MFP board is F-ing expensive, but its what you need im affraid.
                Loading the firmware will also be required (ive always done this so i dont know if there is anything on the board from the factory - i would assume not)
                last i saw they retail between 2 - 3K
                you may be able to get it cheaper though...
