KM Bizhub 600 showing Paper Jam connot reset
  • gregoriojc
    • Aug 2008
    • 56
    [Jamming] KM Bizhub 600 showing Paper Jam connot reset
    Hello Guys,
    I am facing a problem on Konica Bizhub 600 it is showing on the display "a paper jam has been detected remove the missfed paper according to the guide"
    Pull out te adu unit. open cover M3 and removed Misfed" but there is no paper, I replace the the whole ADU unit thinking that there was a problem on sensor, wiring or board. Im out out of idea how to solve the problem, one more thing if there is a paper jam there is possibility that you cannot enter on program mode?
    Pls. help me Guys
    grgoriojc
  • Darren King
    copiertech
    • 652
    Re: KM Bizhub 600 showing Paper Jam connot reset
    I think we need a bit more info. Which tray are you feeding from? Are you duplexing? Have you checked the jam counters to see where it is actually jamming? If there is no paper where the jam is indicated the paper is either not getting there , or the sensor is faulty or dirty.
    Darren
    • emujo
      • Jun 2009
      • 3009
      Time for some "good ol" troubleshooting...somewhere you have a bad sensor or a flag has come off. Use the test mode function in service mode to find out where. Might take some time, but it will be there. Emujo
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • EarthKmTech
          Step aside, noob
          • May 2009
          • 2139
          Edit:
          Sorry, didnt read the original post properly.
          • gregoriojc
            • Aug 2008
            • 56
            As soon as the power put on, this paper jam showing immediately03062012(004).jpgand I can not enter to program mode
            • acusso1234
              Tecnico
              • Dec 2008
              • 250
              Originally posted by gregoriojc
              As soon as the power put on, this paper jam showing immediately[ATTACH=CONFIG]16108[/ATTACH]and I can not enter to program mode
              Is it a refurbished one? I've pissed out a Bh 600 with the same problem 6 months ago...I can gave the id machine number to you, if you like. I only can remember that clicks was less than 250K on it!!
              ... In the minute that you're thinking of giving up, think about why you lasted so long ...
                • 23009
                I was out to a bizhub 600 last week that was jamming in the pre-registration area. After removing the upper registration guide I found a lump of hot glue adhesive used to secure the paper wrappings. I was probably stuck to the top page of the ream of paper. When it got as far as the registration guides it got wedged. The customer ripped out the rest of the paper, and the glue remained. =^..^=
                • fixthecopier
                  ALIEN OVERLORD
                  • 4713
                  They can suck a piece of paper up between the drum and cleaning section. Paper is not supposed to be there, machine can't tell you how to get it out.
                  • SmellsHot
                    Head Tech
                    • 512
                    There should be a jam code right above this message. J2101 or j3206 something like that.....
                    Did you remember to plug the fuser in? The connector can come loose and it will register a jam code. Also like mentioned above paper can get sucked up into the drum unit and register a J21 jam code....
                    Everyone has the right to be stupid. Some people just abuse this privelage more than others
                    • gregoriojc
                      • Aug 2008
                      • 56
                      thanks guys,
                      I will try everything you told me, going back to cutomer place right away
                      gregoriojc
                      • wbm@telkomsa.net
                        I am busy with a Bizhub 751. Showing jam at M13 and cannot be reset. Checked everything and no luck. Please help
                        • pedro arroyo
                          [QUOTE=gregoriojc;293272]Hello Guys,
                          Pls. help me Guys
                          grgoriojc[/QUOTE
                          Hello ...
                          Have this problem been solved ... ?
                          i currently have the same problem...
                            • 23009
                            It would be helpful to know the jam code (as stored in the service mode). =^..^=
