We have a few Konica Minolta C350s that won't reset the counter when we put the new fuser in, and another one didnt reset when we put the transfer belt in. We have tried serveral new ones and none of them work. Is there a solution? Ive called our rep and talked to hotline advisers serveral times and still no fix. Can someone please help me? Thanks
C350 new fuser & transfer belt wont reset
Tags: act, belt, c350, consumable, control panel, fuser, fuser unit, fusing unit, konicaminolta, life, minds, reset, snapped, stalling, traced, transfer
this is what i found out from konicaminolta i hope its not your issue but possiable
Solution IDTAUS0700016EN* Solution Usage 2
DescriptionREPLACE FUSER UNIT message fails to clear after installing a new fuser unit.SolutionCAUSE: Failed PWB-MC.PWB-MC (p/n 4036-7812-01) as necessary
SOLUTION: Ensure that all contact points between main body and fuser unit are properly positioned. Reseat all connectors on the PWB-MC. Replace the
Solution ID
DescriptionPWB-MC (p/n 4036-7812-01) as necessary
Solution
Another fine bend over and hold your ankles fix from the minds of Minolta!
No there are no errors or codes evrything is normal. We had one that did the same thing a few months back and my service manager traced one of the main wring harnesses and one of the pins had snapped in the end and it wasnt getting full voltage and that fixed it, but this one evrything seems to be correct and I still have no idea what the problem is. And the machine is down due to he fusing unit being to its life end and no way of resetting it.Comment
Solution ID
SOLUTION: Ensure that all contact points between main body and fuser unit are properly positioned. Reseat all connectors on the PWB-MC. Replace theComment
Solution ID
Solution
I haven't seen this problem, but you might try updating the firmware to the most current version. I've had other issues that popped up from having old versions.the savin2535 is displaying well bet the hiter lamp is not shining and the lamp had been tested o.k.please kindly help.Samir: No, not again. I... why does it say paper jam when there is no paper jam? I swear to God, one of these days, I just kick this piece of shit out the window.
Michael Bolton: You and me both, man. That thing is lucky I'm not armed.Comment
