Occur error code C-D506 after upgrade firmware
  • brianho80
    • Sep 2009
    • 198
    Hi, does anyone see this error code after upgrade machine firmware?
    Tried to do trouble reset and unset harddisk, problem remain same..
  • Avskrap
    Partner in crime
    • Jul 2011
    • 160
    Re: Occur error code C-D506 after upgrade firmware
    What machine?
    • Bullet71
      • May 2009
      • 29
      Check for Hard Drive version up in Hard Drive settings.
      • brianho80
        • Sep 2009
        • 198
        Originally posted by Avskrap
        What machine?
        Is bizhub 600..
        I cant find version up in the service mode.. Any idea??
        • Albonline
          • Sep 2008
          • 1150
          unset and unplug hdd. there is no version up on 600's, the most likely thing i would try is the firmware . where did you get the file? do you have cf cards that you could swap into this unit? try going down to base firmware and flashing it back up in stages.
          • brianho80
            • Sep 2009
            • 198
            Hi, thanks for the advise.. Manage to solve it by re flashing the firmware to latest one
