Bizhub 750 keep showing " machine warming up"
  • brianho80
    • Sep 2009
    • 198
    Anyone familiar to this issue?
    Initillay i thought of fixing unit thermostat or thermister and lamp but after verify it, everything seem
    fine.
    I replace whole fixing unit with another machine, it working fine after normal warm up is ready to copy.
    Try upgrade the firmware but remain the same; keep showing machine warming up..
  • BBCo
    • May 2011
    • 10
    Re: Bizhub 750 keep showing " machine warming up"
    saya rasa sensor gamma yg kotor. atau mungkin salah satu dari part dibawah ini yg telah limit.
    1. Drum
    2.devloper
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • kyrenecopy
        • Apr 2012
        • 205
        This is a common problem when the NVRAM goes bad
        Testing 1-2-3, testing, testing. Is this thing on?
        • Albonline
          • Sep 2008
          • 1153
          dirty ps1 drum sensor
          • brianho80
            • Sep 2009
            • 198
            Hi guys, thanks for the advise, problem was solved after cleaning drum sensor and adjust gamma but it happen today again...
            Do you think replace drum sensor can solve this problem, hope this settle this issue forever
            • methogod
              • Dec 2008
              • 922
              i have seen the 920s do this often, a few things can cause it, one is the drum/sensors are not letting the machines go through it normal "ready" checks. The other is if the upper and lower corona's are set to clean, and they get stuck, it can say warming up forever.
              Is the fuser get hot? after 5 minutes, do you have lights?
              no lights? and all connections are good, then i would think boards, i have had people same the ADU so hard it screws up the connection in the back.
              you swapped fusers and it works so that should tell you that its not the boards, but the fuser itself. i would check there is no paper in the connection ports, and also that front connector is seated well.
              If the web counter get above 500K that will cause all sorts of crap.
              Just for testing i would pull of the finisher and LCT if you have it. They can also make the weirdest stuff occur.
              if client/you have 2 750/600s you should be able to swap and test pretty quickly.
              • armstrong
                Try to check or clean the fusing lever sensor. its located under the fusing unit.
                • Wilfred Niavi
                  • Dec 2011
                  • 5
                  fine.
                  Check properly the thermistor to see it is coated with soiled toner and cleaned it and replace the upper fixing roller if thermistor have coated lines under that soiled thermistor.
                  Good Luck!
                  • brianho80
                    • Sep 2009
                    • 198
                    Hi guys,
                    Thanks for the advise, have check the fixing unit, thermistor, service drum uni, replace developer and even service the drum sensor board.
                    Everything seem working fine after the services done 2 days ago.
                    Hopefully problem has settle.
