finiser fs503 function without the ru508 ?
  • tasosquesta
    • Jan 2012
    • 11
    I have c6500 with ic 408 and finisher fs 503 but dont have u 508. can operate the system ?
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Re: finiser fs503 function without the ru508 ?
    ru is required for this finisher. In USA it is the ru503 option.
    • ineo+6501
      • Mar 2010
      • 262
      If I remember correctly the IC-408 baby Fiery will not function with anything that requires the RU so you will need either the bigger Fiery or the CREO controller also.
      • Albonline
        • Sep 2008
        • 1150
        this is correct, you could also use on of the non production finishers.
        • empiru
          • Feb 2011
          • 229
          Ok, so all of the following was tested personally:
          C6500 + IC408 isn't going to work with FS503 or FD501 (just like someone else said)
          C6500 + FS503 cannot work alone, you need RU504 OR C6500 + FD501 + RU503.
          The FS503 and RU503 don't have separate power supplies. FD501 and RU504 have their own power supplies, so you need to combine one option with power supply with one without.
          With IC408, you can use FS607; also, this Fiery model supports PF601 (obviously, LU202 too).
          If you want to use a finisher with relay unit, you need Fiery IC303 or Creo IC304.
          I hope this helps, 'cause I had to learn all this on my own, in a few very long nights
          I don't help end-users. Hate me, give me bad reputation, I don't give a rat's a**. Pay a tehnician to solve your problem! We have to live too! What do you do when something hurts? Do you go to a doctor, or do you search it on google/ forums?
