Looking for a little help in fine-tuning some thick-paper settings, as I don't have much experience in that dept. I have a customer that is attempting to use 80lb Cover Paper (Smooth Finish) through the bypass on their Bizhub C451. According to the box of paper, it is equivalent to 215gsm, which should be within spec for the bypass tray. The only wildcard should be the coating/finish, which I am unfamiliar with. Anyways. Even after setting the tray to Thick 3 and setting the Thick Paper mode to "quality", they are getting faint black streaks on their prints.
I am unable to recreate the defect using regular weight paper of any size, also not getting the defect using 8.5x11 80# cover. When making copies of an 11x17 color sample on the 80lb Cover, I get light grey streaks running in direction of paper travel at 1" from trailing edge. I have tried various settings for the loop adjustment and the fuser transport speed, but nothing seems to even affect the streaks. I'd love to just blame the paper, but explaining that to this customer would be....touchy.
I have attached a cropped scan of the defect, though it doesn't show up very well. This is a view of the center portion of the trailing edge.
