bizhub C452 - wide cyan strip (shadow) in sub-scan direction only in colour mode
  • Laserbeam
    replied
    Re: bizhub C452 - wide cyan strip (shadow) in sub-scan direction only in colour mode
    Today I replaced the IU-cyan unit and all works fine. Thank you for your replies!!!
  • Gaffers01
    replied
    yeah it looks like the drum is faulty, maybe sunlight got onto the drum.
  • scottybbb
    replied
    Try a new cyan IU unit.
  • bizhub C452 - wide cyan strip (shadow) in sub-scan direction only in colour mode
    Hi at all,
    each full-color copy or print-out have a wide cyan strip (shadow) in the sub-scanning direction. Black&white mode is okay. The examples in the attachment shows a black& white and a full-colour copy from the test chart. The other are half-tone printouts in cyan, yellow, magenta and black (density 70) from the tech. menu.
    I removed the transfer-belt and checked it visually but no fault was found. After the re-install the stripes are much stronger than before.
    It is a fairly new machine. Total count 9157
    Can the transver-belt occur these stripes or I'm on the wrong way?
    many greetings from Germany
