FS-527 attachment brackets for C220/C280, and C360
  • jmitc1234
    • Jul 2025
    [Misc] FS-527 attachment brackets for C220/C280, and C360
    I know this finisher(FS-527) works with the C220,C280,and C360.. I have looked, and can not find install instructions, or the numbers to order the attachment brackets.
    Any hep would be great.
    Thanksm in Advance,
    Jerry
    • 23002
    Re: FS-527 attachment brackets for C220/C280, and C360
    Have you opened the outer box?
    The instructions are attached with orange tape to the 12" x 20" x 30" box in a plastic baggie. The brackets that you seek are in that box, along with a bridge unit, upper exit tray, brackets, screws, (which you'll need), and C452/C552/C652 inlet guides which you won't need. Perchance did a helpful person unpack this for you, and throw away several parts?
    This is the list of parts in that box:
    (1) Bridge Unit (no part number for the assembly)
    (1) A0HR 1165 01 rear bracket (C220/C280/C360)
    (1) A0HR 1151 01 rear bracket (C452/C552/C652)
    (1) A0HR 1150 01 front bracket (C452/C552/C652)
    (1) A0HR 1166 01 grounding bracket (C220/C280/C360)
    (1) A0HR 1164 01 front bracket (C220/C280/C360)
    (1) A0HR 1167 01 spacer front bracket (C220/C280/C360)
    (1) A0HR 7013 00 lower guide mylar (C452/C552/C652)
    (1) A0HR 7007 00 lower guide (C452/C552/C652)
    (1) A0HR 7000 00 upper guide (C452/C552/C652)
    (4) V116 0308 03 M3 x 8 screws
    (4) V116 0316 03 M3 x 16 screws
    (2) V116 0408 03 M4 x 8 screws
    (1) V137 0408 03 M4 x 8 screw
    (1) A02E 1934 00 M4 shoulder screw
    (1) A0HR 8901 00 upper exit tray
    (1) A0HR 8902 00 tray extension
    • kronical
      Kronic Copier Ninja
      • Nov 2009
      • 230
      Finisher screws and brackets are listed in the "accessories" section of the parts manual. Usually can order seperately or the whole bag of parts/guides.
      • paulrid
        • Nov 2011
        • 206
        Found this thread very useful as I wanted some brackets and the part numbers on the installation instructions aren't KM parts but it's a pain you can't seem to order the whole transfer bed, so does anyone have a working one they want to sell?
        Many thanks Paul.
