c351 jam only when duplex
  • mrfuser
    • 1626
    Simplex is fine. Only jams when it pulls it back in to do second
    side.
    Any thoughts?
    Thanks all
    Kelly
  • Spratt
    • Jun 2011
    • 25
    Re: c351 jam only when duplex
    I've come across a similar sounding problem where the exit drive lever breaks thus the duplex drive not engaging.
    I have attached an image and circled the part which is found above the fuser on the rear side i hope this helps.
    SKMBT_C450%2012061316060[1].pdf
