i work in a school, and we recently had a bizhub c452 installed,i have noticed on some of the school pc's you cannot send to print both login boxes are greyed out, but on other pc's send to print works after login from pc to print, running xp and win7 pcs
bizhub c452 send to print login grey
Re: bizhub c452 send to print login grey
What login boxes? On the printer driver? Or elsewhere?' "But the salesman said . . ." The salesman's an asshole!'
Mascan42
Ibid
I'm just an ex-tech lurking around and spreading disinformation! -
I believe you need to go to the driver properties and activate user accounts.' "But the salesman said . . ." The salesman's an asshole!'
Mascan42
Ibid
I'm just an ex-tech lurking around and spreading disinformation!Comment
1. Printer Properties (of the driver in question)
2. Configure
3. Obtain Device Information
4. Apply
This will enable the Account Track or User Authentication, depending on which option is in use on the machine.Please don't ask me for firmware or service manuals as refusal often offends.Comment
As for the driver, with KM machines I believe you need different drivers for XP and 7.' "But the salesman said . . ." The salesman's an asshole!'
Mascan42
Ibid
looking on downloads there's a few Download Center - Support | KONICA MINOLTA what ones should i downloadComment
looking on downloads there's a few Download Center - Support | KONICA MINOLTA what ones should i download' "But the salesman said . . ." The salesman's an asshole!'
Mascan42
Ibid
ok i have the driver installed on the pc, i have the printer installed is i can see the printer in properties etc, the printer is on a network.
now when i go into printer properties/basic/ authentication/account it greyed out i cannot enter my password for the printer, i cannot see printer in device manager for its driver, so how do i get the greyed out part to be seen so ican fill in my password and start printing, please excuse my greenessComment
Go to your Printer's folder on Windows, right-click on the printer driver, select Properties (or Printer Properties, if you're using Windows 7), and then follow TheOwl's advise above.' "But the salesman said . . ." The salesman's an asshole!'
Mascan42
Ibid
