C250 double image
  • KM7155
    • Aug 2008
    • 145
    [Misc] C250 double image
    Hi guys,
    need help, refer to the attachment.
    already confirm the TS belt is ok, internal print same problem.
    any idea??
  • Toxic
    • 697
    Re: C250 double image
    If i see good it is only red color doubled...?
    Check imaging units,esspecialy magenta and yellow.
    • RRodgers
      • Jun 2009
      • 1947
      Bad IU's I would think. Do a single color copy of something for each color and see which is giving you an issue.
      • mrwho
        Major Asshole!
        • 4299
        Crappy photo.
        Is that A3? And the image repeat is in the main scan direction? In Magenta? I'd wager a magenta laser malfunction... After eliminating the easiest/cheapest possibilities, try to swap the magenta laser with another color.
        Mascan42
        Ibid
        • KM7155
          • Aug 2008
          • 145
          Originally posted by mrwho
          Crappy photo.
          Nope, is an A4, sorry for the crappy photo,
          taken by my mobilephone.
          Thanks for all the input, will try the mag IU.
          • mrwho
            Major Asshole!
            • 4299
            No problem about the photo, we do what we can with what we have. Just be sure to give as much info as possible next time.
            Mascan42
            Ibid
            • SmellsHot
              Head Tech
              • 512
              Go into service mode, test mode, and kick out a gradation print of all 4 colors invidually. This will narrow it down.....
              Everyone has the right to be stupid. Some people just abuse this privelage more than others
              • AjitN
                • Mar 2009
                • 287
                I would like to know which is used for this job. From the image (printed text in image) attached, it looks like Transperant PVC media. If so, it could be Fuser unit. Also please make sure correct toner is used.
                Hope this helps.
                • jarwil
                  • Jun 2009
                  • 61
                  Check the two green levers on the fuser aren't pushed all the way down in the envelope position. Have seen this cause double image and dirty copies. Levers should be flicked up for normal printing
                  • KM7155
                    • Aug 2008
                    • 145
                    Dear All,
                    the problem solved by changing the M IU.
                    • RRodgers
                      • Jun 2009
                      • 1947
                      You're welcome.
