Bizhub 36 A3
  • perkinpop
    • Aug 2025
    [Misc] Bizhub 36 A3
    Hey guys,
    Just wondering if anyone knows how to enable/disable a3 via the bypass?
    • 23010
    Re: Bizhub 36 A3
    If this is the relative to the bizhub 42, it just won't do it. The longest piece of paper it will accept is 14". You probably already know that it'll jam over 14.25"
    Isn't it a weird design? Legal size scan area. Puny document feeder. Print area 11" x 14". It uses some of the same consumables as the bizhub 423 series. There is a crazy attachment kit to allow use of the internal finisher.
    • perkinpop
      Re: Bizhub 36 A3
      Yes it is the little brother to the 42, so its basically a 363 with a few inches missing of the side. We got it understanding that it could take A3 of the bypass and everything seems good but yea like you said it just jams up.
      Such a weird design its like they just slapped a C35 one on top!
        • 23010
        Re: Bizhub 36 A3
        It looks as though it will make a fine high volume printer/copier, but I don't see it as a great scanner. It looks as though they retrofitted the scanner off an HP LJ M3035MFP. We placed a dozen of them 4 months ago, and I haven't done any service yet. Except of course, the A3 paper size situation. =^..^=
        • EarthKmTech
          Step aside, noob
          • May 2009
          • 2139
          Re: Bizhub 36 A3
          they want you to buy the larger machine, ie, 423 series for A3
          this series was specifically designed as a a4/letter size printer workhorse and considering the print engine used it certainly is that.
          a3 while theres no technical reason the engine couldn't do it from the bypass is unlikely to ever be possible due to "marketing reasons" see above.
          as a scanner though, no way, its a c35 scanner and adf which is meant for light to medium duty use at best.
          • perkinpop
            Re: Bizhub 36 A3
            Its just weird how the first news we had on the machine was talking about its ability to take A3 off the bypass and Im sure it can do it in Europe and even the training talks about it...
            • Kidaver
              Ghoulscout
              • Apr 2011
              • 912
              Re: Bizhub 36 A3
              I remember seeing these in school when I went to class for the 423 series....I was not impressed....and we have one sitting at our shop...that a salesmen sold and forgot to mention it didn't do much more than legal....so customer didn't want it and we have to find someone else to sell it to.
              "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
              • EarthKmTech
                Step aside, noob
                • May 2009
                • 2139
                Re: Bizhub 36 A3
                yeah, not happening.
                all the current brochures and specifications specify it as an A4 printer with a maximum paper size of A4/Legal
                looks like they took the bypass tray straight out of the 423 series spare parts shelf, but it certainly wont do A3.
                • PeterG
                  • Jul 2008
                  • 177
                  Re: Bizhub 36 A3
                  Oddly enough, TAEU1100179EN00 says,
                  and I quote.
                  "Yes it is possible. You can print A3 in duplex via using the bypass tray. But it is not possible to copy on A3"
                  WTF.
                  • EarthKmTech
                    Step aside, noob
                    • May 2009
                    • 2139
                    Re: Bizhub 36 A3
                    WTF indeed.
                    does the print driver even support A3?
                      • 23010
                      Re: Bizhub 36 A3
                      and I quote.
                      WTF.
                      That's a nice little conundrum. Two sentences that contradict each other.
                      Here's my advice quoted directly from KM: "Please wait for a while."
