Machine trouble
  • Lukegw
    • Aug 2025
    [Error Code] Machine trouble
    Konica 7115 copier when switched on displays machine troube on screen and then displays service call error code C0000. Other times it displays paper jam but when i open the door there is no paper. please help.
  • Mikey
    • Sep 2009
    • 54
    Re: Machine trouble
    Clean the clutch/solenoid connected to the main motor. Lubricate if possible. You can reset the trouble by turning off and on the machine.
    • JustManuals
      • Jan 2006
      • 9838
      Re: Machine trouble
      Paul@justmanuals.com
      • agudmove
        • Jun 2009
        • 70
        Re: Machine trouble
        Fault Code - just could be the main motor needs changing. Check nothing is binding the fixer unit also.
        Paper Jams - with lift up tray in down position, make sure rear paper guide is right up to paper. If it happens all the time the torsion spring needs changing.
