C6501 C6500 Fuser making clikcing sounds after service...
  • methogod
    • Dec 2008
    • 919
    This is one of two fusers we swap as needed so we always have a working fuser.
    Just replaced all 3 rollers, fusing belt, lower bearings and busings (they were grinding). This is the fuser that came with one of my C6501's so i know it has around 1.2m on it.
    I can see any thing loose when advancing manually or with the top open.
    anyone ever have this, i am thinking a loose screw is allowing something that is tensioned some play.
    A side note, when i run heavy stock it works fine, when i run 80gsm coated it really makes waves, BUT my fuser does this but no ware as much.
    I know the registration roller is due, just waiting for parts.
  • Gort
    Copier Demon
    • Oct 2011
    • 50
    Re: C6501 C6500 Fuser making clikcing sounds after service...
    Gears? Several of the fuser gears need to be replaced @ 600k. Check the service manual for the replacement interval for the fuser gears.
    Sorry, I do not have a cat in my avatar.
    • methogod
      • Dec 2008
      • 919
      right on, 3 one way bearings was causing some slippage. Without the clicking noise we would of never known because it wasn't at failure yet.
      • Gort
        Copier Demon
        • Oct 2011
        • 50
        You may also want to replace the torque limiter under the lower roller. If is has over 1 million clicks it is ready to crap out, I replace the torque limiter and gears at the same time. When it fails you will have jamming and strange fusing problems.
        • JustManuals
          • Jan 2006
          • 9838
          Paul@justmanuals.com
