Re: C6501 C6500 Fuser making clikcing sounds after service...
Paul@justmanuals.com
You may also want to replace the torque limiter under the lower roller. If is has over 1 million clicks it is ready to crap out, I replace the torque limiter and gears at the same time. When it fails you will have jamming and strange fusing problems.Leave a comment:
right on, 3 one way bearings was causing some slippage. Without the clicking noise we would of never known because it wasn't at failure yet.Leave a comment:
Gears? Several of the fuser gears need to be replaced @ 600k. Check the service manual for the replacement interval for the fuser gears.Leave a comment:
This is one of two fusers we swap as needed so we always have a working fuser.
Just replaced all 3 rollers, fusing belt, lower bearings and busings (they were grinding). This is the fuser that came with one of my C6501's so i know it has around 1.2m on it.
I can see any thing loose when advancing manually or with the top open.
anyone ever have this, i am thinking a loose screw is allowing something that is tensioned some play.
A side note, when i run heavy stock it works fine, when i run 80gsm coated it really makes waves, BUT my fuser does this but no ware as much.
I know the registration roller is due, just waiting for parts.Tags: None
