BizHub 250 - Fax problems
  • shaneferguson
    Hi all,
    Hope you're well. First post on the forums, I hope you can help.
    We have just had a BizHub 250 with fax set-up in our office.
    We can send and receive faxes, however - when we send a fax it comes out the other end has landscape not portrait. As though you have sent an A5 fax/2 pages on one A4.
    Can anybody please inform me if there is a setting that I need to change.
    Many thanks,
    Shane.
  • kingarthur
    • 1367
    Originally posted by shaneferguson
    Hi all,
    Many thanks,
    Shane.
    On this m/c you can only fax or scan landscape, it is not possible to do as portrait. which is the main reason this m/c gets rejected.
    • pepper38_cnd
      Field Service Manager
      • Aug 2005
      • 1075
      Change your header setting to "Inside image area"
      Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
      Now into Ip TV KODI Boxes
