forward tx error
  • kon
    • 55
    forward tx error
    google e-mail intermittently gives forward tx error. bizhub c360 and 283. c451 on same network never errors. all smtp authentication settings are correct. the only differences between c451 and the other 2 is the c451 had equitrac installed at one time but has since been removed. all machines have valid certificates.
  • nmfaxman
    • 1702
    Re: forward tx error
    Google has a limited storage for email.
    I have run into Daemon failures to google accounts that the mailbox was full.
    Some people think it is a free offsite storage for files until they hit the limit.
    Create your own gmail account for testing.
    • kon
      • 55
      We set the size limit to 24 mg to test but single 1mg documents dont work also. and this is intermittent. We also have set up another account to test and same thing.
        • 23002
        milligrams? In a way that explains a lot. I always wondered what an email actually weighted. =^..^=
        • TheOwl
          • Nov 2008
          • 1732
          What are the settings that you are using?
          smtp.gmail.com
          Port 587
          Enable Start over TLS
          xxx@gmail.com as the username
          password
          • kon
            • 55
            Same settings as the c451. and tried as in the solutions database. I believe as you have listed.
