differences between bizhub c550 vs bizhub c452
  • jtymabel
    • Aug 2008
    • 164
    need info on the following machines. Is print quality any different?customer wants a bizhub c452 and i have available a c550. (not familiar with the bizhubs)thanks
  • redhawkpath
    Re: differences between bizhub c550 vs bizhub c452
    Hi
    Bassically the two copiers are the same. of course the 550 is faster but they are made on the same platform. Therefor, there is no difference.
    • blazebusiness
      SanDiegoCopierRepair.com
      • 1257
      C451/C550/C650 are older discontinued models and the newer versions of those platforms being sold now are the C452/C552/C652. The differences are minimal. The newer models have a faster processor & 2 GB memory and 250GB HDD The exact same print and scan resolution as the previous generation-no improvement. Good machines, though.
      • kingarthur
        • 1399
        Originally posted by blazebusiness
        C451/C550/C650 are discontinued models and the newer versions of those platforms being sold now are the C452/C552/C652. The differences are minimal. The newer models have a faster processor & 2 GB memory and 250GB HDD The exact same print and scan resolution as the previous generation-no improvement. Good machines, though.
        The C452/C552/C652 have now been replaced by the C454/C554/C654 so C550 is now getting a bit "old"
