Konica Minolta 7145 f26-1 issues.
  • legaspiclg
    • Oct 2011
    • 72
    [Error Code] Konica Minolta 7145 f26-1 issues.
    Hi there,I have 3 units of Konica Minolta 7145 that has the same problem, it is indicating f26-1 to me it is ATDC sensor, My problem is, i dont know where to buy that sensor, anybody out there caN help me where to buy that sensor?, or maybe there is another problem aside from the sensor? Please help.Cesar
  • kingarthur
    • 1333
    Re: Konica Minolta 7145 f26-1 issues.
    have had lots of F26-1 problems, but never changed a sensor, is the dev unit turning, wipe the mag roller clean & power up, is the roller covered again by dev/toner, if not, it's the dev motor that's failed, have you checked the toner recycle unit at the back of the m/c, these get blocked , so no toner gets into the dev unit, is the m/c noisy, check the drum recycle unit isn't blocked.....is the toner bottle turning....
    • legaspiclg
      • Oct 2011
      • 72
      Hi Sir,
      Thank you very much for a very good advice. i will definitely do what you said to me., i will let you know what happen then.
      Cheers!
