bizhub 350 not printing. 0x0000999a
  • brent
    • Nov 2008
    • 1212
    I can ping the unit but it will time out. and then I replaced the mfb board. still same thing. there is an exclamation point on the screen in the lower right corner as well. I am headed out to take a pwb a. but have not had this issue with amy of my 200 250 350 machines. am I headed the right way? any thoughts would be appreciated
    brent
  • Hansoon
    • Sep 2007
    • 3374
    Re: bizhub 350 not printing. 0x0000999a
    Is this somehow related to printing from Google Maps or so? We had machine lock ups because of this. If this is the case it needs a special FW. I'm just in the middle of the process clearing this matter up cause its also new to me. Hans
    • JustManuals
      • Jan 2006
      • 9838
      http://www.justmanuals.com
      Paul@justmanuals.com
      • brent
        • Nov 2008
        • 1212
        in the manual I was able to track it down to the fax board that fits onto the mfb board. of course I don't have a spare. but that is what the code kind of pointed me too. I am headed out to just take the board out to see if it wont die on me
        brent
        • SPBE
          • Sep 2010
          • 70
          I have seen this also if a print job is stuck in the queue or there is an IP conflict.
          • Hansoon
            • Sep 2007
            • 3374
            http://www.copytechnet.com/forums/ko...rebooting.html Hans
            • brent
              • Nov 2008
              • 1212
              I replaced all 3 items that was associated with that code. memory fax board and the mfb board. it still wont work. actually 2 things are happening. when I clear go to the screen there is an ! on the memory side. and I can ping it. but it sends packets over. and then it acts like it is going to work. then it times out. I do not see anything on it's que (on the copier screen) and all of the sudden it will just abort. once I am trying to ping it. the machine works fine other then that. It does have a fax board copies just fine as well. they don't scan. I have reset the machine. I total cleared it. and image data. clear. it just gets stuck and aborts. I replaced the parts with good working parts. any more thoughts>?
              thanks
              brent
              • SPBE
                • Sep 2010
                • 70
                Unplug the network cable from the machine and see if it aborts. If it doesn't, try pinging it to see if you get a reply.
                • brent
                  • Nov 2008
                  • 1212
                  I can try that. I have been there 3 times today and am sick of that machine.. lol
                  the google chrome thing was not it. they didn't try to print. they don't use google chrome.
                  this thing only reboots when I try to ping. if it was unplugged we could't even ping it to make it try to fail.or amI overthinking this thing?
                  • Hansoon
                    • Sep 2007
                    • 3374
                    Who said Google Chrome? My machine locked up after prints coming from Google Maps/Earth. Hans
                    • fixthecopier
                      ALIEN OVERLORD
                      • 4714
                      I have had the abort thing with a bad packet being sent. Machine keeps trying to resend, machine keeps aborting. I would take a laptop and take their network out of the mix. If you can print like made without any errors from the laptop, it puts the problem in their system.
                      • brent
                        • Nov 2008
                        • 1212
                        hans. I looked up that link you put. and darren king mentioned google chrome. that is why I did.
                        • brent
                          • Nov 2008
                          • 1212
                          fix. they are using a lap top. and it goes to a switch. the switch is going to a small printer which is h ooked up. because my machine wont print. and our machine. I can see it from the printer on. then like i said earlier. the printer gets an ! right where the memory usage is ( lower right hand corner) and reboots. every damn time...... thanks again
                          • JR2ALTA
                            • Feb 2010
                            • 2030
                            This is a known issue, You didn't have to replace anything. It's a Windows 7 thing and yes it does it for maps a lot too. Clearing the print queue at the PC will fix it, or a more permanent solution is to change the printer port from LPR to RAW... or the other way around I don't remember.
                            • Hansoon
                              • Sep 2007
                              • 3374
                              Sorry Brent didn't realize that. Hope I didn't sound rude....... Hans
