bizhub 350 not printing. 0x0000999a
  • brent
    • Nov 2008
    • 1212
    #16
    Re: bizhub 350 not printing. 0x0000999a
    I appreciate everyones input. I was able to turn off the slp and snmp off in the pagescope screen. rebooted the machine. and it has been great ever since. I am hoping all will be good now. I figured I changed parts for nothing. but it was good experience. we started at a corrupt file. looking to see if there was anything in cue. then checked out if there was a tcpip address conflict. nothing but the turning off those 2 settings worked. just wanted to report that is a fix. thanks
    brent
    • RRodgers
      • Jun 2009
      • 1947
      #17
      Originally posted by JR2ALTA
      This is a known issue, You didn't have to replace anything. It's a Windows 7 thing and yes it does it for maps a lot too. Clearing the print queue at the PC will fix it, or a more permanent solution is to change the printer port from LPR to RAW... or the other way around I don't remember.
      Yep, do that then pop in the special firmware and you are good to go. I've been doing machines with abort codes like this for the past month. Flash it, and done, done and done.
      • brent
        • Nov 2008
        • 1212
        #18
        hans. no problem man. I did not take that as being rude. I just really
        appreciate everyones help on this. and this the end result. it is fixed at this point
        this machine has firmware with 62 twards the end. have had no problems
        in the past 4 years it has been there. then this pops up. darn machines anyways.
        brent
        • Dave10
          • Jul 2008
          • 197
          #19
          Every single time we have had this, it's because someone has added a new computer and the print driver port settings default to LPR. Change to RAW. Clear all print queues, and if necessary, change the IP address. Make sure all drivers are set to RAW. This is a known problem with Windows 7 and sometimes XP.
