Bizhub c552 message only black and white printing is possible
  • wesdog
    • Oct 2010
    • 10
    Hi All
    I have a konica Minolta bizhub c552 coming up with " only black and white printing is now possible" and "fax cannot be used currently" fax option in service mode is not set.
    Any ideas guys?
  • Shadow
    PHD in Sh!t Disturbing
    • Sep 2011
    • 455
    Re: Bizhub c552 message only black and white printing is possible
    have you checked the firmware level?
    confer with KM to see if this is a related issue.
    I'll check my info latter and get back to you if I locate anything about the B&W only issue.
    $hit Happens - Deal with it and move on.....................................sigpic....................................Lock & Load
    • Shadow
      • Sep 2011
      • 455
      you will need to check and see if they have user authentication or account tracking enabled.
      if these are enabled and you have public user enabled as well there may be some restrictions in place.
      find out if any one in the client's office made and administrative changes to the machine through the web interface.
      not that they would admit to it though.
      if you can access the web interface check the above mentioned settings and then go from there.
      it sounds like they have restrictions for the colour printing and use of the fax unit.
        • 22999
        How about the simple things? Is it out of one of the color toners? Is it due for a color imaging unit replacement? Have you changed the fax setting to "Set"? What have you done so far? =^..^=
        • JustManuals
          • Jan 2006
          • 9838
          Paul@justmanuals.com
          • stedros
            • Oct 2011
            • 34
            its possible that the black imaging unit is still on and the imaging units for colour have yielded up so i think u need to replace the colour imaging units
