Bizhub 600 pcq
  • acsolutions
    • Jun 2010
    • 519
    [CQ] Bizhub 600 pcq
    Hello, bizhub 600 pcq back grounding, developer replaced after 50k copies. causing atdc error, after cleaning ok. I'm thinking of doing another dev. change and would like to know if there is any adjustments I should make so this problem does not occur again. Doctor blade, bias or corona adjustments. I have never replace the collection roller on one of these machines, it does not seem to be dumping toner but I am getting stray toner on the leading edge on every sheet as well. Thanks
  • Darren King
    copiertech
    • 652
    Re: Bizhub 600 pcq
    There is no ATDC sensor on this machine. Probably a Dmax error. Remove drum and clean sensors. Run drum pecuriarity starting with "cartridge set" and then do the rest in proper order. If the backgrounding is bad run about 25 skyshots or until you can see light through to deplete toner then run drum peculiarity.
    Hope this helps.
    Darren
