C364 Service Mode
  • Mat Wilson
    • Sep 2010
    • 26
    C364 Service Mode
    I have just started to run up a new Konica Minolta C364 machine but i am unable to get into service mode. Unfortunately i have not completed the training so i dont have a service manual to look at the process. I have started the training but the customer needs the machine ASAP. Any help would be greatly appreciated.
  • JSC
    Gimp
    • Dec 2006
    • 618
    Re: C364 Service Mode
    Stop-0-stop-0-1 machine will then ask for a password in the display which is 9272 9272 9272 9272 then press "end"
    The gene pool could use a little chlorine.
    • kingarthur
      • 1356
      when you go into it, turn off the necessity for the password & also change the admin password to the usual
      • Bizhub
        • 147
        Don't forget the new passwords as K-M say if you forget them you would need to replace the MFP board and the SSD chip.
