Bizhub 500 code c2803
  • rocky246
    • Feb 2007
    • 91
    #16
    Have you check to see what error 5 is. There was a chart on KonicaMinolta website that explained what each error meant. Just a thought.
    • Martin_alba@yahoo.com.ar
      #17
      Code Error sc 23-09
      I have a bizhub 500 with an error code of C2309, does anyone know what this is?
      • fixthecopier
        ALIEN OVERLORD
        • 4713
        #18
        Originally posted by ITCHYFINGER
        With All You Have Replaced, Try Replacing The Drum With An Oem Drum And New Developer. I Have Seen Non Oem Drums Cause This Problem..also If Your Black Patch Dont Appear You Can Get Funky Errors To Developer.
        If the count on the drum and developer are off by a lot, it will wreck your world. Drum and developer should go at about the same time.
        • sherryhuang00001
          #19
          toner chip
          We are a manufacturer of toner chip and toner cartridges for laser printer . please check our price list at your attachment!
          To tell you a good news,now we have worked out many new chips with almost the best quality in China,Such as Samsung SCX-4828,OKI B4500,OKI 2200,OKI 2400,OKI 4400,OKI 4600,OKI 4100DN,OKI 4300DN, Samsung ML-1640,Samsung CLP-315 and Samsung CLP-310,Samsung SCX-4300,Samsung ML-2240 printer mainboard chip,Olivette D.COPIA 300MF ,M200chip,Epson Aculaser M2000D toner chip,KyocerA TK-710/TYK-712 chip,Samsung CLP-350 ,HP Black Universal chip,HP 1600/2600,3600,Kyocera Kyocera TK-715,675,130,140,310,312,320,322,330,332 etc chip,HPC1215 chip,Lexmark C522 chip,Samsung CLP-300 chip ,Xerox C1110/Dell 1320 chip,HP 36A ,Epson 2600,HP 2020,HP 2025,HP 2035,HP 2055 ,HP P4014,HP P4015 ,Xerox DC7760 toner chip and Xerox Phaser 7760 drum chip etc...
          www.printercolorltd.com
          • thuo
            • 155
            #20
            BIZHUB 500
            check the home position sensor for the toner bottle.make sure its clean and in position.otherwise you need to modify the toner bottle mechanism so that the notch actuates the sensor properly
            • tritwi
              • May 2011
              • 4
              #21
              Bizhub 360/420/500 C28 03 error
              Originally posted by Downunder
              Hi Guys, working on Bizhub 500... 135,000 copies on meter, came up with c2803 -- TCR abnormality. Did trouble reset a number of times. Went into imaging process ran a TCR, fault still there. Added some toner to dev box, ran TCR again. Fault went away. Put the toner bottle motor under test, bottle turns ok. 300 copies later fault came back. Replaced starter, did TCR, no luck, Replaced ATDC sensor, did TCR, no luck, replaced print control board, no luck, gave the copier good vac and clean, Checked all the connections on the boards. at end of TCR run it comes up with "error 5" -- any help appreciated. Glad the weekend is here!
              Hi,
              I had this kind of trouble many many times with this series of machines. The problem is in the toner supply unit. You have to remove the back cover and the main board then you'll have access to the toner supply unit. Strip it and check all the gears especially the one made of two parts and blocked by the small plastic arm. I usually replace all the toner supply unit. You might then have to perform the tcr adjustment again or replace the developer.
              Good luck
              Marco
              • digicor
                • Jul 2008
                • 1159
                #22
                Re: Bizhub 500 code c2803
                i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i DONT WANT TO WASTE TIME AND MONEY ON NEW PTS AND DV AND FROM WHAT IVE READ ABOVE, IT LOOKS LIKE THAT DOES NOT SOLVE THIS.
                • JustManuals
                  • Jan 2006
                  • 9838
                  #23
                  Paul@justmanuals.com
                  • tritwi
                    • May 2011
                    • 4
                    #24
                    The problem is common in bizhub 420/500. You have to remove the back of the machine,remove the control board and remove the toner supply unit. I usually prefer to change the entire toner supply assembly but you can also try to disassemble and repair it. Usually the problem is a torn gear,the one coupled to the metallic screw shaped shaft. It sometimes turns and sometime it doesn't giving you wrong density and the code 28-03. You'll also see there are a couple of gear "one that drives another". They tend to split a little not allowing the assembly to turn regularly. Remember to carefully reassemble the unit taking care at the lenght of the screw that holds the solenoid and to reinstall carefully the solenoid actuator and spring. The part code if you want to buy a new one (the easiest thing to do) is: 50GA-320 1
                    If you have more questions email me and I'll send you the sm and part list files
                    Marco
                    • marco1508
                      • Sep 2010
                      • 32
                      #25
                      check the hoper, specifically, the gear of the supply toner, I was found in many times the gear with damadge in the toohts, so the toner must be supply very slow and the machine display the C-2803 error, you run the tcr adjustment with the "error 5" display, check the hoper, also may be the icp in the printer controller, check it with a tester.
