kmbh c452: Trouble Code C2251 then C2204
  • kizi57
    • Dec 2010
    • 69
    Hi All
    I'm experiencing problem with my bizhub c452, it first started to show trouble code c2251 and now showing trouble code c2204.
    My technician came and knew the problem was from Cyan Toner, the toner which i insert it was melt (balls balls) and not in fine powder form.
    What should we do in order to sort out this problem?
    Rgds
    Barry
    KMBH C452 End User
    East Africa, Tanzania
    • 23003
    Re: kmbh c452: Trouble Code C2251 then C2204
    There are three common causes for toner to fuse inside the machine.
    1) Storage: What temperature is the area that the new cartridges are stored?
    2) The fan filters may be blocked, or fans not running.
    3) Environmental: What is the ambient temperature in the room the machine is located? I don't have the machine specs in front of me, but I'm guessing 50F to 80F is the desired room temperature.
    • kizi57
      • Dec 2010
      • 69
      The temperature is aroud 24C to 30C.
      The main problem is how to resolve the error codes above mentioned, there is also a bad noise from waste toner motor.
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • RRodgers
          • Jun 2009
          • 1947
          Install all new toners and all new drum units. Be sure to vac out the toner add system first as well. I think the drum unit's are about $500 each x 4 should be a couple of grand, and since you are spending that much talk them into either throwing in new toners or giving you a really good deal on new ones.
          GL.
          In the future, give the toner bottles a shake (just like it says to do on the sticker) and listen to see if it sounds like rocks in there. If it does, DO NOT install it.
            • 23003
            30C sounds a lot like 86F, definitely at the high end of your environmental window.
            And according to the Weather Underground it is 85F in Dar Es Salaam right now:
            Weather Forecast - Tanzania, TN - Local & Long Range | Weather Underground
            • kizi57
              • Dec 2010
              • 69
              so what is your solution for my post
                • 23003
                Fix the machine environment first: 10C to 27C.
                Then follow RRogers suggestions. There's no sense fixing the consequences without fixing the cause.
                • Mr Spock
                  Vulcan Inventor of Death
                  • Aug 2006
                  • 2064
