BH 250 Tray Switching
  • morpk
    • Oct 2010
    • 97
    Hey Dose anyone remember the soft switch setting to enable tray switching/ lock out a tray,
    I have a customer that wants to put letter head in a tray and lock it off.
    it's one of those settings that i have not needed to use in a few years and everyone in the office is scratching their heads saying "Oh yeah i remember that setting" but no one can remember it.
    Ta
    • 23006
    Re: BH 250 Tray Switching
    I wasn't around for the C250. Isn't there a media type setting in Utility/Counter > System Settings > Paper Settings ... or something like that? =^..^=
    • morpk
      • Oct 2010
      • 97
      Yeah the C250 is fine it's the BH 250 (B&W ONLY) that's different
      • blazebusiness
        SanDiegoCopierRepair.com
        • 1250
        Ta
        That is the factory default in the BH250------see the following
        Automatic paper-tray-switching feature
        If the selected paper tray runs out of paper while a job is being printed and a
        different paper tray is loaded with paper meeting the following conditions,
        the other paper tray is automatically selected so printing can continue. If the
        optional LCT is installed, a maximum of 3,650 copies
        Operating Conditions
        The paper is the same size.
        The paper is positioned in the same orientation.
        The paper is the same type.
        Order for selecting the paper trays
        As a factory default, when a different paper tray is automatically selected, the
        next paper tray in the following list is chosen.
        1st tray
        2nd tray 3rd tray/LCT 4th tray Bypass tray
        NO AUTO TRAY Switching occurs if you don't have the same paper size and same orientation/direction available in a different cassette
        • morpk
          • Oct 2010
          • 97
          1st tray
          Yeah that's cool so now i have different paper in tray 4 and i want to take tray 4 out of the auto selection...... and go......
          sorry if i wasn't clear :|
          • blazebusiness
            • 1250
            Actually...rereading your post I see you mentioned that you want to lock out a tray. You were clear.....my mistake. I'll try to read slower next time LOL..........
            • morpk
              • Oct 2010
              • 97
              All good, i just had a coffee so I'm reading everything fast
              • Darren King
                copiertech
                • 652
                Just go into utility mode and set the paper tray to "Special". That will isolate the tray until it is chosen from the control panel.
                Darren
                • morpk
                  • Oct 2010
                  • 97
                  Darren
                  ahhh yes that is a good suggestion that will work well if i don't find they switch settings that's for that suggestion
