Bizhub 7145 (also known as a Konica Minolta 7145)
  • Milkman
    • Aug 2025
    I have a friend that has this printer. I want to do stuff like e-mail from the printer, create PDFs from the printer, or fax from the printer. The printer appears to need some software to communicate with (on a computer), and can't actually do this from the printer itself. I have gone through all of the configurations, and it is all correct.
    Does anyone know where I can find this software?
  • TheOwl
    • Nov 2008
    • 1732
    Re: Bizhub 7145 (also known as a Konica Minolta 7145)
    The software that you need is called an 'Email Server'.
    To fax, you will need a 'Fax board and phone line'.
    • JustManuals
      • Jan 2006
      • 9838
      And BTW.........The 7145 is NOT a Bizhub machine.
      • nmfaxman
        • 1702
        OPTIONAL....
        Type Optional IP-432 Print Controller
        PDL Support PCL5e/6
        Speed 45 pages-per-minute
        Resolution 600 x 600 dpi
        Memory 64 MB / 192 MB
        Network Card 10/100 BaseT
        Print Drivers Windows 95, 98, ME, NT 4.0, 2000, XP
        Options 5.0 GB HDD (HD-107) required for downloading
        fonts only, Adobe PS 3 Kit (PS-344)
        • copytechman
          • Nov 2008
          • 947
          Weirdly enough a number mine DO say Bizhub on them. Notably the the 7222-35 series and the 7145 among them! But it tiz a pure Konica regardless.
          Regards!
          A.
          • Milkman
            Thank you for the reply "TheOwl"
            So this printer is completely self sufficient then, and doesn't need any external server software to allow the printer to scan to PDF then??? I assume that I just have the authentication settings wrong then.
            The printer looks like it should be able to do all of the functions without external software, but the problems that I had, along with the environment that this printer used to run in, made me believe it required external software.
            Also, it is DEFINITELY labeled as a Bizhub printer, but thanks for the clarification.
