C300 makes a black square in center when making copies
  • adecanmin
    • Oct 2010
    • 298
    Gentlemen.
    I went to customers office. MFB was bad, no network connection. I replaced board from a used machine with the NVRAM from used machine. Customers machine is working. I took the bad board with the NVRAM to do some troubleshooting. I figured I would have to sacrifice machine since I would not replace the board. As luck would have it I came across a board without the NVRAM pack on it. I put the NVRAM in and I get a black square in the center of the page when I make a copy. It prints fine, scans fine, copies with square. To verify it is NVRAM I briefly put it in an another C300 and it copied the black square. I removed the battery before I came across that board. So I definitely corrupted the NVRAM. When I booted up the machine it was in Japanese. I performed the clear, stop, 07139 * to restore the data. I still got the black square. I did use the NVRAM recovery tool same result. I went through the set up procedure, no luck. Upgraded firmware, no good. Maybe there is something simple I've overlooked.
    Adrien
  • JR2ALTA
    • Feb 2010
    • 2033
    Re: C300 makes a black square in center when making copies
    Is this similar to your black square?
    • adecanmin
      • Oct 2010
      • 298
      I think I missed something in the set up. I'll go through the set up again.
      Adrien
      • brent
        • Nov 2008
        • 1212
        kind of confused me with changing all the nav ram but typically if a black square is reproduced. there was a step missing in the installation. go back and perform installation procedures again... it should take care of it
        brent
        • adecanmin
          • Oct 2010
          • 298
          I did make it a little confusing with all the NVRAM talk. This is the first time I've had to mess with it. I did learn a bunch however.
          Adrien
