C280 Language Button
  • jarwil
    • Jun 2009
    • 61
    Is it possible to disable or delete the language button from the control panel? The one down the bottom right hand corner.
    • 23008
    Re: C280 Language Button
    No, but ... if you store enough additional option buttons it will bump out the Language button. We did that in class. =^..^=
    • TheOwl
      • Nov 2008
      • 1732
      Yeah, we change the shortcut keys so that there is density and original type as the two shortcut keys and that removes language from the screen.
      1. Utility / Counter
      2. User Settings
      3. Copier Settings
      4. Shortcut Keys
      I think that is the way in.
      • jarwil
        • Jun 2009
        • 61
        Thanks for that guys. Worked a treat.
        Another solution supplied by Copytechnet.
        Thanks again
