bizhub c 220, yellow giving half blank and permanent error p 21
  • ogaliandy
    • Apr 2012
    • 14
    Bizhub c 220 showing error p 21 and the yellow colour giving half blank even after changing the yellow imaging unit and yellow drum, and after cleaning the PH unit and IDC sensor, has anyone seen such a problem
  • kingarthur
    • 1220
    Re: bizhub c 220, yellow giving half blank and permanent error p 21
    i'd swap the yellow ph unit with the one next to it & see what happens, but i'd suspect something blocking the ph unit
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2142
      cant do that, c220/280/360 uses a one piece laser unit.
      there have been issues with HV boards on this series machine too, more diagnosis and a print sample is required to make an educated guess.
      • AjitN
        • Mar 2009
        • 287
        PH Unit Glass Cleanning rod has come out from Cleanning mechanism. You can feel if rod is very loose compare to other three colors.
        Hope this helps
        • JustManuals
          • Jan 2006
          • 9919
          Paul@justmanuals.com
          • ogaliandy
            • Apr 2012
            • 14
            Hi,
            Thanks for the feedback, i will scan the print out and attach,
