C360 web interface access reboots the mfp
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    every time without fail no matter which browser or workstation is used, brand new machine out of the box.
    anyone had this yet ?
    I will be seeing it in person on Thursday armed with an mfp board and ram, failing that I suspect it could even be NVRAM.
    Everything else is ok, ie configuring the machine via the control panel etc is fine, prints too. Just the web interface is causing this issue. Latest F/W has already been installed with no effect.
  • pepper38_cnd
    Field Service Manager
    • Aug 2005
    • 1075
    Re: C360 web interface access reboots the mfp
    I know this will sound strange, but I have seen some weird issues when the switch is 1G and the patch cord or wiring is only Cat 5 not the required Cat 5e or Cat 6 to support a 1G connection.
    Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
    Now into Ip TV KODI Boxes
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2139
      I will try lock it down to 100, half duplex when i go out there.
      I will report back my findings.
        • 23008
        Similarly, I had a C360 on a new setup that would print one page, then drop off the network every time. Same solution as pepper38. At 100MBs it worked fine. =^..^=
        • EarthKmTech
          Step aside, noob
          • May 2009
          • 2139
          'twas none of the above
          it was caused by a failed attempt by I.T. at configuring and connecting the machine to PSES, i suspect there was corrupt PSES Authentication Manager API data stored on the HDD.
          I did indeed witness repeatable attempted web access to the mfp cause it to instantly reboot.
          formatted the HDD and all back in order, configured, connected and managed by PSES.
          Didnt even take out my F-ing screwdriver...
