223 Replenish Paper
  • JR2ALTA
    • Feb 2010
    • 2027
    223 Replenish Paper
    I think I have a case of a customer slamming the drawers, but I am not sure how to fix it.
    Both cassettes consistently say "replenish paper", unless drawer is closed very firmly, and/or jimmy around enough.
    So I believe the process should be
    1) Cassette Detection
    2) Size Detection
    3) Engage Lift
    4) Paper Present
    My machine recognizes cassette, size, but never engages lift. It almost immediately says "repl. paper"
    No C-codes
    I have replaced lift motors, metered board, swapped upper limit sensors, inspected cassettes.
    Thanks for your time!
  • nmfaxman
    • 1703
    Re: 223 Replenish Paper
    Something is keeping it from seating right. Could be as simple as sitting on a flat surface with all feet level. Place it on the floor and see how it works. Floors have to be level to ground. Just a thought.
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2140
      I had this recently on one tray only, and ended up having to change the tray rails. The one on the right was butchered either by a geriatric dumbass technician, or an abusive user.
      on this particular machine closing the tray can now be done with 1 finger, though i did strategically apply some lubricant too.
      • eg101
        • Jan 2005
        • 131
        You did check for paper left in the machine behind the tray didn't you?
          • 22917
          I had a case of this on a C360, but the cassette structure is similar.
          When you remove the cassette there is a "T" shaped structure molded of the cassette base that blocks a photointerrupter ... or it's supposed to. I found that by pushing on the tray I could get it to lift, or stop lifting. The photointerrupter is buried, installed from the backside. To test my hypothesis I took some black colored self-adhesive mylar and extended the flag at the back of the tray by 4mm. It worked perfectly.
          Then I thought about what a pain it would be to get to the photointerrupter. So why do I have to do that? It works just like this (and still does). =^..^=
