Bizhub C550 wierd print issue odd shape outlined in white in the center of images
  • jeremyb503
    • Aug 2009
    • 38
    Anyone have an idea of how I could fix this problem? See the attachment. Thanks!
  • 907tec
    • 434
    Re: Bizhub C550 wierd print issue odd shape outlined in white in the center of images
    Might wanna take a peek at your transfer belt. You haven't been running labels through your machine, have you?
    • Elle
      Formerly the Dispatcher
      • Jan 2008
      • 51
      how funny i was just thinking that exact thing as i was looking the img over - aparently you were typing while i was looking
      needless to say i concur wtih the labels assement
      • jeremyb503
        • Aug 2009
        • 38
        I hate to ask (is my ignorance showing again?) but where is the transfer belt located? Is there a place in the manual I should look?
        • jeremyb503
          • Aug 2009
          • 38
          And by the way, thanks for the quick reply!!
          • jeremyb503
            • Aug 2009
            • 38
            You guys were totally right. I took look at the transfer assembly and there was a piece of a label or something stuck to it. I peeled it off and there is still some residue so I am wondering what I can use to clean it off the will not damage the belt. Any ideas?
            • Elle
              • Jan 2008
              • 51
              i've used alcohol (90%) and clean cotton with good success - just dont rub too hard and wipe it again with a clean dry cloth afterwards and you should be fine
              • minimerlin
                • 851
                Glass cleaner, the spray stuff not the cream! Spray onto a cloth made into a pad, get it quite wet then wipe the belt to remove residue let the belt dry and it should be OK.... Or charge user for a belt?
                Please do not PM me without asking first.
                • jeremyb503
                  • Aug 2009
                  • 38
                  Thanks for the assist. After a good clean the issues is resolved!
                    • 23007
                    ... and there is still some residue so I am wondering what I can use to clean it off the will not damage the belt. Any ideas?
                    Get yourself a small bottle of lamp oil (paraffin). It loosens adhesive nicely without damaging transfer belts, drums, guides, rollers, plastics, ... anything. Sure, it's slightly flammable but you shouldn't be smoking anyway. I evaporates quickly leaving no residue. It's miraculous. I used to use Dispersant until it became obsolete. =^..^=
                    • jeremyb503
                      • Aug 2009
                      • 38
                      Well now I've done it. Apparently I did not get all the adhesive off last time and the spot started to come back, so I cleaned it will the paraffin and followed up with glass cleaner. Now when I print the whole image is really dark and on elements with a white background the white background prints Yellow.
                      What have I done? All I did was clean the belt. I didn't touch anything else. I have tried running several hundred blank sheets just to see if there was some residue that would clean up, but no dice.
                      Top of the photo shows how it looks now, bottom is what it looked like before.
                      • minimerlin
                        • 851
                        Have you done the gradation adjust? What is the test print like?
                        • jeremyb503
                          • Aug 2009
                          • 38
                          thanks for the reply.
                          It seems to be ok now. After waiting a couple of hours I ran a test print and it looks fine. There must have been some residue that needed to evaporate.
                          How do I do the gradation adjust?
                          • pepper38_cnd
                            Field Service Manager
                            • Aug 2005
                            • 1075
                            Are we being PUNKED? First the picture that anyone who's been servicing color machines for more than 10 minutes would reconize as a lable on the transfer belt. Followed by where is the Transfer Belt. Now how do I do Gradation? What's next? How do I get into service mode? Even Paul didn't take the bait and offer him a Service Manual!
                            Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
                            Now into Ip TV KODI Boxes
                            • Avskrap
                              Partner in crime
                              • Jul 2011
                              • 160
                              Seems we've got an end-user on our hands...
