IU / Dev unit reset
  • Max
    • Oct 2011
    • 558
    IU / Dev unit reset
    Hello,Is there a way to reset Image unit/Developer unit through service mode? From what i understand if i have latest f/w on the copier it can be done. I tried on a few different models in the counter menu of service mode but i was unable to highlight the Image unit option.Should i be looking in the different option or the f/w not up to date? Right now i have to chip them but i don't always have the right chip on the car for a particular copier.Any help would be appreciated.
    Thank you.
  • Hansoon
    • Sep 2007
    • 3385
    Re: IU / Dev unit reset
    I have no idea but we have some very bright guys around here, they just look into their crystal ball and will know instantly which model you are talking about. Their answer will than be there in a split second. For sure.
    Hans
    • Max
      • Oct 2011
      • 558
      Iam not after a specific model just in general and especially the latest product. As they all much alike i would guess the procedure would be the same or very similar between models (if there is a such a thing at all)
      • Albonline
        • Sep 2008
        • 1151
        search pplm on the konica website.
        • dannysaunders
          • Oct 2012
          • 6
          Thereare Dipswitch settings that you have to change after putting on the latest firmware for the newer machines. There is a bulletin about the settings on Konica's Website.
          • Max
            • Oct 2011
            • 558
            Unfortunately i am not a Konica dealer so i have no access to the bulletin. However i do have access to latest f/w. i guess it is not enough to just u/g f/w...
            • styaner
              The firmware does not RESET the image unit but prolongs its life.
              it also prolongs the transfer belt and fuser and the drums in the newer models
              you can trythese, not the latest firmware but the switches should work
              if you can find the latest bulitin that would be best for i got this a year ago or so
              C203-GR4-R6 -C253-GQ4-R6 C353-GP4-R6
              SERVICE->UNIT CHANGE->IMAGE UNIT->SERVICE
              ->SELECT- TONER NEAR EMPTY->NO
              SERVICE->SYS-1->IULIFE ->SUSPEND
              -SERVICE->SYS-2->SOFT SWITCH->51->11001000->FIX
              -SERVICE->SYS-2->SOFTSWITCH->55 ->00001100->FIX
              C451-C550-C650GP4-R6 -SERVICE->UNIT CHANGE->IMAGEUNIT->SEVICE
              -SERVICE- >SYS-1->IULIFE ->SUSPEND
              -SERVICE->STOP “0” CLEAR->LIFE SETTING ->NO STOP
              -SERVICE->SYS-2->SOFTSWITCH->51->11001000->FIX
              -SERVICE->SYS-2->SOFT SWITCH->55->00001100->FIX
              C220-C280-C360-C452-C652 –C552 -G00-D0
              -SERVICE->STOP “0” CLEAR ->LIFESETTING ->NO STOP
              -SERVICE->SYS-2->SOFTSWITCH->51->11110000->FIX
              -SERVICE->SYS-2->SOFTSWITCH->55->00001100 fix
              • Max
                • Oct 2011
                • 558
                Thank you ill give it a go
                • Darren King
                  copiertech
                  • 652
                  Soft switch 51 should be set to 11010000 on C203/252/353
                  Darren
                  • bronco31
                    • Aug 2009
                    • 174
                    old thread i know... this is weird......on 2 C353s i have been unable to "fix" the dpswitch setting?? 51 and 55 just go back to all zeros.. is there another dpswitch that needs to be latched..
                    thx..
                    • Darren King
                      copiertech
                      • 652
                      thx..
                      For C353 you need GPG-R6 firmware installed. That should fix it.
                      • bronco31
                        • Aug 2009
                        • 174
                        never mind....you have to highlight the hex box then hit fix..sweet, no more IU message.damn im good
                        • bronco31
                          • Aug 2009
                          • 174
                          thx Darren.. now get back to work!
                          • Darren King
                            copiertech
                            • 652
                            Who said I was working in the first place. lol
