konica bizhub c454
  • glasstec
    • Sep 2010
    • 25
    [CQ] konica bizhub c454
    hi can anyone help,i have un boxed new bizhub c454 internal prints fine,when copying through the doc feeder or glass it is giving me vertical lines a centermeter apart cyan and magenta,not sure if i have missed out on something on the setup,i have tried setting up again using setting gradation adjustment .check stabilizer...print and copy and repeated the steps about 6 times no joy,can any one help me please
  • Avskrap
    Partner in crime
    • Jul 2011
    • 160
    Re: konica bizhub c454
    You've missed something in the setup, simple as that. Konica says to do a data clear between attempts. Re-do it and make sure not to skip out on anything. Rather spend five minutes doing something you find trivial than to spend an hour figuring out what the hell went wrong.
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • bobe
        • Oct 2011
        • 38
        Do again the color calibration, setup the time. I had the same problem. 1st time because of the time setting and 2nd time color calibration
        • Itsthepaper
          Supervisor
          • Dec 2007
          • 91
          Yep, those lines are common when a step was missed in setup. When entering date and times in different areas of set up make sure to clear the current date and time even if it's correct, then physically type in the date and time.
          Love the Job Love the Work.
