Konica Bizhub C 253 C2152 Error Code
  • Doug James
    • Jan 2012
    • 935
    Code won't clear, Took transfer belt out and it's working OK. Is their a common fix to this problem ?
  • pepper38_cnd
    Field Service Manager
    • Aug 2005
    • 1075
    Re: Konica Bizhub C 253 C2152 Error Code
    Try taking out the screw that holds the rear belt lock mechanism and replacing it with a screw 1/4 inch or shorter I have seen this screw come in contact with the gears (tranfer retracksion drive gears) behind the bracket if over tightened. Or if the wrong screw is put in after disassembly.
    Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
    Now into Ip TV KODI Boxes
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • Synaux
        • Mar 2012
        • 1224
        "Relevant Parts:
        Fusing motor (M5)
        Transfer belt retraction clutch (CL7)
        Transfer belt retraction sensor (PS31)
        Printer control board (PRCB)"
        • Doug James
          • Jan 2012
          • 935
          Thanks you guys... Really appreciate your help...
          • Avskrap
            Partner in crime
            • Jul 2011
            • 160
            The standard fix for this is, if the belt is already factory modified per the technical notices, to tear the machine to pieces and replace the sensor mentioned by Synaux. It's located behind the main drum drive assembly. Replacing this sensor has solved the problem for me, every time.
            • Darren King
              copiertech
              • 652
              Avskrap is right. This isn't a 20 minute job though, so don't be in a hurry. The modified sensor assembly is available from KonMin.
              Darren
              • MFPTech
                • 486
                Darren
                The sensor's position can be adjusted by using a long screw driver .... it will save lots of time
                • 173545
                  • 16
                  I found this helpful.
                  • Doug James
                    • Jan 2012
                    • 935
                    Wow... I am so grateful...
                    • Hansoon
                      • Sep 2007
                      • 3389
                      Great tip. Had this today with a BH-C-353 one of our techs was rebuilding. Thanks to you and this wonderful panel found the solution immediately here without loosing another hour to find it myself. The screw was obstructing the white lever behind the rear locking bracket of the transfer belt.
                      Thanks again for taking the time to post your solution!
                      Hans
