Code won't clear, Took transfer belt out and it's working OK. Is their a common fix to this problem ?
Konica Bizhub C 253 C2152 Error Code
Tags: None
Re: Konica Bizhub C 253 C2152 Error Code
Try taking out the screw that holds the rear belt lock mechanism and replacing it with a screw 1/4 inch or shorter I have seen this screw come in contact with the gears (tranfer retracksion drive gears) behind the bracket if over tightened. Or if the wrong screw is put in after disassembly.Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
Now into Ip TV KODI Boxes -
Paul@justmanuals.com
The standard fix for this is, if the belt is already factory modified per the technical notices, to tear the machine to pieces and replace the sensor mentioned by Synaux. It's located behind the main drum drive assembly. Replacing this sensor has solved the problem for me, every time.Comment
Avskrap is right. This isn't a 20 minute job though, so don't be in a hurry. The modified sensor assembly is available from KonMin.
DarrenComment
Attached FilesComment
Thanks again for taking the time to post your solution!
Hans“Sent from my Intel 80286 using MS-DOS 2.0”
