Bizhub C284 Custom paper sizes?
  • cap0319
    • Oct 2012
    • 34
    I have a customer that uses 8"x5" paper, can a custom paper size be set in a tray other​ than the bypass?
  • Kidaver
    Ghoulscout
    • Apr 2011
    • 912
    Re: Bizhub C284 Custom paper sizes?
    You can check the change tray settings under paper under the Copy->Basic->Paper setting on the screen. If printing you may need to check the setup up in the printer properties. User guide is on the CD you might go take a look at it.
    "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
    • cap0319
      • Oct 2012
      • 34
      Nope, when the bypass is selected and you go to the tray settings button, custom size is an option, when any other tray is selected and you go to the tray settings button, there is no custom size option.
      Same info is found in the SVC manual, I'm just hoping for maybe something I've overlooked, or a novel way to fool the machine ;-)
        • 23002
        Be sure to feed this paper in the R direction, the long way. Even on machines with a very short paper path 5" length is too short. =^..^=
