BH 600 scan options missing....
  • havokprod
    • Oct 2012
    • 159
  • Shadow
    PHD in Sh!t Disturbing
    • Sep 2011
    • 455
    Re: BH 600 scan options missing....
    read the manual and go in and disable the enhanced security mode.
    this should allow you to reset everything and get the scanning working again.
    have you contacted tech support?
    I believe there is another procedure you have to do as well, but can't remember all of it at the moment.
    $hit Happens - Deal with it and move on.....................................sigpic....................................Lock & Load
      • 23006
      Check to see if your HDD is "Set". The function to enable it is in Sys1 or Sys2 > options ...
      • Darren King
        copiertech
        • 652
        This may help.
        Unable to create or edit a one-touch destination
        Solution:
        Cause: "Registering and Changing Addresses" is set to "Restrict" in the Administrator Settings
        Solution: To change address restriction setting please perform the following:
        1. Log into Administrator Mode.
        2. Select System Settings.
        3. Select Restrict User.
        4. Select Restrict Access To Job Settings.
        5. Change "Registering and Changing Addresses" from "restrict" to "allow".
        6. Exit out of "Administrator Mode".
