Bizhub 500 no toner in develop assy
  • aco.bk
    • Sep 2012
    • 130
    Problem is:
    my bizhub wont suplly toner in develop assy.
    bottle not spininig and printouts are very bad!please help.
    machine is in ready state without error code.
  • JustManuals
    • Jan 2006
    • 9838
    Re: Bizhub 500 no toner in develop assy
    Paul@justmanuals.com
    • rrrohan
      • Sep 2011
      • 1977
      Originally posted by aco.bk
      Problem is:
      how do you know there is no toner in the Dev?
      Wouldnt that give you some form of TCR error if it wasnt supplying?
      • aco.bk
        • Sep 2012
        • 130
        today installed new developer and get error code c2801!
        • kingarthur
          • 1369
          have to carried out the dv set up
          • ni311
            • May 2008
            • 658
            Go to Service Mode -> Imaging Process Adjustment -> select TCR Adjustment -> press Start key
            When changing developer, be sure not to conduct the copy operation before completion of the TCR adjustment.
            The adjustment is completed in about 180 seconds. When there occurs a TCR adjustment error due to the developer agitating operation not completed successfully, the message "operating ..." disappears and an error code is displayed.
            Konica Minolta Error Codes - Explanations and Solutions
            • tech51
              • 846
              Seems to me that if you have no error codes relating to toner supply and the bottles not spinning you have the correct amount of toner in the developer. These machines normally throw error codes a lot so the lack of one is quite unusual!!!
              I would suspect your copy quality problem lies elsewhere.
              If you could post some examples of the poor copies maybe the good people on this site would be able to help you further..
