konica c252 code c3851
  • W242
    • Aug 2009
    • 43
    [Error Code] konica c252 code c3851
    I'm getting a code c3851 on the Konica c252.
    Can this only be reset with a new fuser unit or replacing the pico fuse?
  • rrrohan
    • Sep 2011
    • 1977
    Re: konica c252 code c3851
    Originally posted by W242
    I'm getting a code c3851 on the Konica c252. Can this only be reset with a new fuser unit or replacing the pico fuse?
    im going to say no. if its giving temp errors resetting the life counter of fuser wont make any difference.
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • Darren King
        copiertech
        • 652
        If it continues to throw this code even after a trouble reset then YES, replace the fuser.
        Darren
        • W242
          • Aug 2009
          • 43
          I'm looking thru the manual, I can't find the way to reset a trouble code. How do you do it? where in the manual does it show this?
          Thank you
          • kingarthur
            • 1350
            if you have the service manual & you have read it...then you know that alongside the description it says the reset type is "RANK A"....you should be able to find what you need from there with a little further reading
            • W242
              • Aug 2009
              • 43
              yea thanks for the kind response. sometimes konica hides that info or words it so you can't tell that its a reset. I was just looking for a quick fix as I am new to this machine. I have done some more looking and did find the reset info.
              Also thank you for the other responses, still having a problem so I will replace the fuser.
              • ni311
                • May 2008
                • 658
                Just start the copier from the main button with the Utility / Counter pressed. Keep this button pushed until you will see Trouble Resetr button on the LCD. Release the button and touch the button on the display; an 'ok' should appear beneath. Restart it from the main button. Voila!
                Konica Minolta Error Codes - Explanations and Solutions
