Bizhub C452/ NEC IT45C6 Image Problems
  • bdesire
    • Oct 2012
    • 62
    [Electrical] Bizhub C452/ NEC IT45C6 Image Problems
    This machine produces bands going through the image on full color copies/prints, I don't see it on copies with 10% color coverage. So far I've changed the transfer belt, transfer roller and fuser. Removed and cleaned the LSU assy and replaced the MFP pcb and installed new firmware with no luck. The image shows up on the paper at the transfer belt. I have not replaced the IU's because the lines are consistent through each color, any help will be greatly appreciated.
  • kon
    • 55
    Re: Bizhub C452/ NEC IT45C6 Image Problems
    I have seen hv power supply do this or bad contacts
      • 23010
      I'd be interested in seeing a scan. =^..^=
      • JR2ALTA
        • Feb 2010
        • 2033
        I have seen IUs cause problems for the preceding colors, since black is furthest to the right it can cause issues for the other three.
