C451 Error C2151
  • Elmo
    • Feb 2010
    • 541
    [Error Code] C451 Error C2151
    I have a machine that throws up C2151 at start up
    ive checked that the pressure sensor and motor work
    no other related faults or codes
    can anyone help am i missing something
    I Used To Live To Fix Things Now i Fix Things To Live
  • Elmo
    • Feb 2010
    • 541
    Re: C451 Error C2151
    replaced PRCB and DCPU still get same code
    does anyone have a schematic for a C451
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • Albonline
        • Sep 2008
        • 1153
        To correct, the following actions may need to be taken:
        a. Replace the Transfer roller (p/n A00J R715 00).
        b. Check PS50 (Pressure Welding Alienation Sensor) and replace if necessary (p/n 9335 1300 61).
        c. Replace M3, 2nd Image Transfer Pressure Retraction Motor (p/n 4037 R709 00).
        d. Replace PRCB, Printer Control Board (p/n A00J H001 06).
        e. Replace DCPU, DC Power Supply (p/n A00J M404 05).
        • Elmo
          • Feb 2010
          • 541
          Thanks for the reply
          I have removed all the items you listed and tested them in another machine
          they all work fine
          think i must have a broken wire somewhere
          • Elmo
            • Feb 2010
            • 541
            Got it
            found a fractured wire between the prcb and m3 motor
            if i moved the wire i could get signal at the motor
            move it again and signal was lost
            replaced wire problem fixed
