A new contract for onsite copiers caused our xerox copiers to be removed and new KM Bizhub 363's to be installed.
At first everyone was impressed. An all in one unit. Smaller, sleaker design. and so on.
But now people are horrified because, often times, after they use the copier and depart, the next person to use the copier will get "copies of the previous user's print outs" !?
It might be a mere nuisance to have someone else's work print out when you are expecting yours.
And it might be okay if it were merely a uneventful document such as a company newsletter that printed.
But certainly NOT for those times that the previous user was copying documents such as their own medical forms and supporting documents.
Or personal legal documents and such.
People are so scared about copying personal paperwork on the bizhub 363 and having it reappear for the next user, that they are walking to the far end of the building (about the distance of 1 to 2 city blocks for some users) to copy their paperwork using an old Canon copier. (An old canon copier that only prints what you tell it to and does not toggle between scanning and/or copying and/or ?????; which results in jobs being left in the que for the next user to see/read).
So far no one has found the answer to getting these bizhub 363's to copy only the current job and then quit.
Some people said to push RESET several times when done, but that did not fix the problem.
The manuals we have for the bizhub 363 did not go into detail enough to tell us how to get this problem resolved.
One solution:
Some people run 3 or 4 additional copy jobs using a BLANK piece of paper, after their copy job, to clear out any remnants of their job.
It works, but is cumbersome.
Any solutions would be greatly appreciated.
It is probably just some single setting that needs to be toggled.
Thanks in advance.
One solution:
Thanks in advance.
